the only work well with win8
is the version 6:52
for earlier versions GV still has not said if there will be updates
is not interested in clearly inform their customers
I have downloaded the Demo (V6.52) on Win 8 OS and activated it with my licence no. Version 6.0 from my original install CD bring an error on Win 8 during installation.
--------------------------- Bassists come most deeply ! self made pc: Q9550 at 4 x 2.85GHz, 12GB RAM, GTX 560Ti, 3 x HDD (one fast 1TB HDD for Audio/Video only), Windows 7 pro / 64bit, EDIUS 6.52 - pc is optimize for Audio editing Laptop: Lenovo with i3-2370M 2.4GHz, 4 GB RAM, 500GB SATA HDD, Windows 8 pro / 64bit EDIUS 6.52 - Laptop is optimize for nothing
That is because version 6.5 is a paid upgrade meaning you have to purchase it.
I know this.
I have test the trial of EDIUS 6.5 on my Laptop with Win 8 first. Then I decided to buy it (I'm new on EDIUS). My dealer send me a 6.0 Version CD and a Update CD to V 6.5. Installed it on my desktop PC on Win7 without problems. On my Laptop, I deinstalled the demo, because there are limitations maybe. Then I try to install V6 from install CD without luck. So I take the demo file 6.52, install it again, licenced it with my number and all run fine ....
You do not need V6 installed to install V6.5. The trial version would work fine as you describe althogh you will not have all the DVD menu templates. The installer for 6.5 should be on the "upgrade" CD. After installing this you then need to put on the latest patch (6.52) as it is unlikely the full installer is a 6.52 installer.
Or you could just leave it working as it is now and live without the DVD templates.
EDIUS silver certified trainer. Main edit laptop: DVC Kaby Lake desktop processor laptop, 32GB RAM, 3.5Ghz i5 desktop processor, nVidia 1060, Windows 10. Desktop: 4Ghz 9900K processor, 32GB RAM, nVidia 1660TI GPU, Windows 10. Desktop: 2Ghz 12 core Xeon processor, 32GB RAM, nVidia 1060, BM Intensity Pro, Windows 10
