What does this mean-red box with numbers?
  • What does this mean-red box with numbers?
    I have some noisy footage which I export as Wav and process with Isotope RX2. work great at reducing the hum and such. I save the processed audio and import back into my project. Ungroup the clip, delete the original audio and drag the new audio to the time line. however, after I do this, I get a little red box on the video track and audio track with a number like -35 on video and +35 on audio. I don't see anything that looks out of synch even when I set resolution to 1 frame. What is it, should I be concerned, and how do I fix it if necessary?
    Thank you.
    PS-I take it back. I was only looking at the beginning of the clip at 1 frame. at the end, the audio is now a little longer. what is going on?? What do I do now?
    The extra audio was silence from 43:09:07 to 43:09:08. I split the time line and deleted that section but when I regroup, I still get that red box and the same +/- 35 on the 2 tracks.
    No idea what's going on. appreciate your help.
    Last edited by chappyware; 03-07-2013, 03:39 AM. Reason: did a little more looking.
    Gigabyte mobo with i7 K2600, 16G Ram, Storm Mobile, nVidia 570 but I'm just a hobbyist.
    IIRC the red number indicated audio offset from the linked video.
      So how to fix this?
      I ungroup again, right click and select audio offset. I delay the +35 by 35 and I get a blue box saying audio offset but when I re-group, the red +/- 35 still appears. What am I doing wrong? Advancing does the opposite but the red boxes don't change when I regroup.
        Try clearing your track mapping - sounds like you're putting the clip somewhere that only part of the clip can "sit" and EDIUS is making adjustments to make it happen how it thinks you want it.
          no luck
          reset all mapping and re-imported, dragged to timeline etc. still get +/35 red box when I group. Do I need to worry? any other thoughts on fixing this?
            Is Isotope RX doing something unwanted to the audio?
            I'm sure it is as there is that 1 little section of silence added at the end of the clip after processing. what to do?
              This means that the audio and video are out of sync and the numbers tell how many frames out of sync. The common error when this happens on Insert is that one or all of the Sync Buttons are off.
                all synch buttons on
                any other ideas- the sound seems synched ok and this last one I just did has a +307! any other ideas? Maybe it's not a problem but a quirk of RX2 processed wav files???Appreciate any more suggestions/comments
                  Can you provide a screenshot?
                    This maybe a kludge, but I would leave the original audio on the time line as is and just mute it (no need to ungroup). I would put the sweetened audio on a separate audio track, and use the original audio as a reference to synch it based on waveform.
                      here's how I get this result
                      The playback seems to be right in synch. they number in the red box is 307 if you have trouble seeing it.
                        32 bit vs 64 bit version of RX2-does it matter?
                        I use the 64 bit version of RX2 just for speed advantage but save it as a wav file for importing into Edius 6.5. Would that matter? I assumed not.
                          Chappyware
                          Have you tried using RX2 inside edius, I have no problems, just a matter of directing Edius to the plug in in the VST plug in Bridge
                          The plug in is in the Program files(x86)/Steinberg\Vstplugin directory, add to the bridge and it will appear in the Audio filters, Izotope folder, 6 filters will present themselves
                          Dosn't even slow Edius down, I think from memory only one does not work
                          Has to be the 32 bit one but Edius sorts that out from the VST directory
                          Regards Barry
                            VST bridge problem
                            Tried the suggestion above. Copied the RX2 win32 dll files to a folder called VST Plugins. Used System Settings-Effect-VST Bridge to point to that folder. None show up in the Effects panel under Audio filters. Ideas?
                            Izoptope says RX2 can be used as VST plugins-maybe not the spectral repair one but the others should work. So, what am I doing wrong?
                            I also copied these DLLs to the EDIUS 6.5\Plugin\VST folder and they STILL don't show up. The folders show up under the system setting-Effect-VST Plugin dialog but nothing on the effects palette. Am I missing a step?
                            BTW, these are not from the Edius Bonus disc but purchased separately from Izotope and are the latest versions.
                              No don't have to move any files
                              Just point the VST bridge to the directory as Quoted see below, it has already placed the interface files there
                              C:\Program files(x86)\Steinberg\VstPlugin
                              Restart Edius and they will be there
                              Yes Spectral repair is the one that does not work
                              Regards Barry
