WMP 11 will not open my .AVI Files
  • WMP 11 will not open my .AVI Files
    I capture my files using DV capture using the Canopus .AVI codec.
    After upgrading media player to version 11, the .AVI files will not open.
    Earlier versions played the captured files just fine.
    Any ideas or fixes?
    No sorry can't think why that would be as I had WMP11 on my PC and Canopus files opened fine.
    Are you getting any error message? Is it possible that WMP has unregistered one of the codecs?
    Software:
    Edius 8.5 Workgroup
    NewBlue FX
    Hitfilm Ignite
    Vitascene 2
    Newblue TitleMotion Pro
    Smartsound 5.8
    Desktop:
    MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
    Laptop:
    MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
    Cameras:
    Panasonic HC-VX870 4K
    GoPro Hero4 Black
    Panasonic GX8 (Stills & Video)
    Garmin Virb 360
      It becomes non-responsive when I try to open a file.
        Wmp 11
        I just tried a file I captured using 4.51c and it plays fine on WMP 11. It dose'nt look like it is a player or Canopus problem.
        Bob
        Computer
        Case Antec P180 - MB Intel 975XBX2 - CPU Intel Q6600
        Memory 4 gig DDR2 800 - 2 Drives SATA 300 + 500
        Video Card Nvidia 8800 GTS 320
          Try installing GSpot and open and analyze the AVI file using it. GSpot can also display a list of codecs on your system, and report problems with them.
            I am still using 4.24 and might just wait until I install the next Edius update that fixes Imaginate and hope it solves the problem.
