Quicker way to import XDCAM?
  • Quicker way to import XDCAM?
    Hi all, I have just received around 150 scene folders shot in XDCAM format. I have to mix these into another video (with AVCHD). Each folder contains an MP4, SMIL, and an XML document.
    I want to import the MP4 video file to my project in Edius (6.07) and can do so, but only individually. Is there a way to pull the video files out of the folders as a group rather than opening every single one first?
    ( I am prepared to be considered stupid if it appears on virtual page XXX in the manual but I haven't been able to find it as yet).
    I currently have the XDCAM master folder on my hard drive, copied from the drive the other cameraman sent to me.
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
    First and foremost...
    did they copy the complete folder structure? If not you may be out of luck!
    The Sony Clip Browser is really the only way to handle them from Camera to PC.
    Then again into Edius. (imo)
    Edius Media browser will strip valuable metadata when copying clips. Yes, it works, but not in my workflow.
      Yes I believe so.
      I have just noticed that when I open my project with their hard drive plugged in, clicking on the source browser, then XDCAM EX, then (H), all the clips appear in the bin. But I don't know how to save them from the bin to the computer hard drive in this extracted form, although I have all the files on my computer in folders.
      I have to send the drive back so I either need a solution or I open and import them all manually. Rusty, I do have Sony PMB but it doesn't want to see the drive.
      (I'm just getting my stupid hat out of the cupboard- it is never very far away!)
      Rod Pike
        My workflow is usually as follows:
        1. right click on XDCAM item in source browser
        2. click 'open folder' & navigate to the original XDCAM root folder
        3. when clips are loaded I select all the clips I need & on right click I "add and transfer to bin"
        Does this work for you?
        Andreas
        Andreas Gumm
        post production / authoring
        Windows 7 Ultimate,
        GV hardware: 3G Storm
        PC 2
        GV hardware: HD SPARK
          Select all needed in the Source Browser right clip and use add transfer to bin.
          This will copy the files to your Project folder.
            This is the Browser you need for XDCam the consumer PMB or AVCHD NXcam utility will not work for XDCAm. http://pro.sony.com/bbsc/ssr/micro-x...oad.shtml#apps. I use with the EX3 to bring into a folder I create on my hard drive for each project I do which also includes directories for the other 4 AVCHD cameras. Clips appear just like in the AVCHD version rather than files which are limited to FAT on the hard drive unit. Then just bring clips into Edius as normal by dragging from the clip XDCam browser into the bin.
            Ron Evans
            Ron Evans
              From day one customers here use the following workflow:
              1. Open Sony ClipBrower
              2. Drag the picons from the Sony browser to the Edius Bin
              3. Done
                I didn't realise that the actual files would be duplicated and copied to the project file. I always assumed that bin files were just holding points/markers for the originals on the computer hard drives.
                Rod Pike
                  I don't know to which method you are replying but in EDIUS you have 2 methods:
                  1 add to bin ...will point to the original location
                  2 add transfer to bin ..will make a copy of the files in the project folder and EDIUS will point to those.
                  So it is a matter of how you do it.
                    Steve, thanks so much- a simple thing that I didn't know! (I have found the stupid hat!). Transfer to bin it will be- problem solved. Thankyou all
                    Rod
                    Rod Pike
                      That is why I like keeping transfer to PC and then backup before editing. Doing this wrong with file based camcorders can loose all your work. You might think your saving time but loosing all your files is much worse than one extra step. This way I also get to decide where the files go rather than the default project folder. When my friend shoots with his EX3 I just have his hard drive overnight to copy and backup before I give it back to him. Which if course he then formats to shoot more stuff at his work !!! Don't want to get that sequence wrong !!!
                      Ron Evans
                      Ron Evans
                        Here is the link to the Sony download site:
                        Discover Sony Shoulder Camcorders with superb ergonomics for ENG and field based shooting. Find out more.
                        The new XDCAM Browser V2.1 is available.
                        NOTE: XDCAM Clip Browser has been discontinued and replaced with XDCAM Browser. It's doubly confusing because the old software was at V2.6 the new software with the slightly changed name started at V2.0!
                        I use the program to move clips from drive to drive without a problem.
                        Hawke,
                        Edius 8.31WG - Asus Sabertooth X58 - 3.2GHz I7 960 - 12GB RAM - SSD C drive - Win7 Pro. 64bit - BM Intensity pro 4K. TMPGEnc Movie plug-in. FCB. Sony PMW-EX1 & Panasonic HDC-SD900. Atomos Samurai Blade
                          I just use the .MP4 files on their own and don't even bother with the browser software, Edius XDCAM import or anything.
                          Go to the root directory of your video files on your XDCAM SxS card and do a search for *.MP4. Once all the MP4s are in one search window select all and copy across to a directory on your hard drive. I usually name d1, d2, d3 etc for the different cards.
                          Drag the d1, d2, d3 directories directly into he bin
                          Raja Singh
                          Sadha Video
                          UK
                          Gigabit Ethernet
                            Another option is to use a file manager Total Commander 8.0. It has a neat button called "Show all files in current dir and all subdirs". If the sort mode is set to "by file extension" all MP4s files are sorted next to each other. They can be easily selected, copied, dragged over to Edius or ... ...
                            TC 8 is a superb utility for general Windows file management tasks.
                            1st System: Edius 9, TMPGEnc VMW6 & AW5, ASUS P9X79, Core i7-3930K, Intel SSD 330 180GB, GeForce GTX 570, Corsair Graphite 600T Mid-Tower, Sony Optiarc AD-7280S, 16GB RAM, 12TB , Canopus ADVC-300, 2nd System: Edius 9, HP ZBook 17 G3, i7-6700HQ CPU @ 2.60GHz, 16GB RAM, 512Gb SSD, 1 TB HDD. Cameras: Panasonic DVX200, Fuji X-T3, Sony RX10
                              3. Done
                              Correct.
                              This has been covered so many times previously. The way Zorro suggests is the easiest and the method with the least steps.
                              Navigating down directories and extracting the mpeg files IS NOT the way to go. Metadata is not maintained using this method and problems can also occur with spanned clips.
                              The Sony software was written for a reason, why do people insist on making life complicated for themselves?
                              Main Editing System: Sinclair ZX81 0.75Mhz chip (Overclocked to 12Ghz), Liquid Nitrogen Cooled. 48k of RAM, Compact Cassette tape drive (9600 baud), 4" B&W monitor. No keyboard - all input by thought transfer from a colander on my head. Gives me 180 layers of 4k in real time (all with 3D PIP added) and can encode and burn a 2 hour Blu Ray in just under 12 seconds. Custom editing chair that floats on magnets 2 feet above the floor. I am also able to travel in time.
