6.51/2 Exporter Vistitle and crashes
  • 6.51/2 Exporter Vistitle and crashes
    1. A customer on 6.51 wants to export from 1080 50i project to FLV VBR to end up with an 8min 50 sec video at 50Mbytes max file size for streaming. The minimum Bit rate in exporter is 2MBits/sec so he can't use the Edius exporter. He needs about 0.7Mbits min and 1.5Mbits max to achieve this, so as far as I can see he has to use a 3rd party encoder as its not possible from Edius. Why is this minimum there at such a high figure?
    2. Vistitle refuses to stick being rendered, it does when the timeline is in view but after some more edits elsewhere its unrendered again. Why?
    3. Edius 6.52 seems to generate poison projects that won't even load any more and crash alot. Didn't have any of this nonsense with 6.51. I have sent off a crashing project crash dump to support but not even the decency of a reply. I have one project that can't be edited any more and just contains a render all and add to timeline, otherwise I couldn't export it. Luckily at that point it was finished.
    1. you can type 0.7M and press tab, then type 1.5M and press Tab
    (this is only possible if your project setting is switched to SD)
    a HD project will not let you go below 2M otherwise quality would be very bad
    2. render the title with Shift+Q after quick select in and out, it will never break the render thereafter
    3. no problems here
      Output bit rate
      Surely though even if the project is 1920 by 1080, if the exporter frame size is custom 1024 by 576, a bit rate below 2 mbits VBR ought to be allowed, why should the project have to be set to SD when the output size has been set lower than the project?
