Creating a soft edge around clip?
  • Creating a soft edge around clip?
    I want to have an image burn through a section of another.
    I want the image to have a irregular outline, a freehand type eclipse with a soft blured edge.
    When I use Liquid XE, I can use a keyer which has a freehand tool, which you draw around your image, created a mask, invert it, add soft edge...done in 30 seconds!
    Can Edius do something similar.
    I have tried Layouter and I can get the image with a soft edge, but it is even all around the image.
    Mark Twittey
    Walkabout TV
    Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
    Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
    5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
    Think you need to watch the tutorials and check the manual. Get the EDIUS way.
    This will save you lots of posts and lots of time. :)
    Use the Mask filter.
