How do I recover the Bin? Thanks!
Bin has dissapeared in Edius 6.01
Manual?
Press H for all pallets. B for bin -
Then it is hiding after something else or it is on another screen if you had 2 screens.
You can use the default layout which is shift + alt +LComment
Try updating 6.01 to the latest version.Last edited by Jerry; 10-21-2012, 09:41 PM.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
You can download Edius 6.08 from the registered users section.
It's free for registered users.Jerry
The improvements between 6.01 and 6.08 are considerable. Have you registered the software? If so, it is easy to download and install.Jerry
Can you post a screenshot of the interface?
How many monitors do you use?Comment
Move the timeline and the monitors to the other monitor,
is there anything behind them.
To do a screen shot press print screen on keyboard
Open paint and then cntrl+V save as .png and upload to the forum.Last edited by Jerry; 10-22-2012, 12:16 AM.Jerry
You could create a new user profile to see if that fixes it.Jerry
