maximize takes minutes
  • maximize takes minutes
    Minimizing Edius (4.51c) works immediately as any windows program should do.
    Reactivating Edius takes minutes. It uses a small portion of the CPU while the Windows taksmanager says it is not responding, but finally it is on top again, but frosen.
    Is this a known issue? I've seen a minimize/maximize issue, but it was related to user accounts. I just did a simple minimize and immediately tried to maximize again.
    If the solution is difficult to find, it is maybe easier to disable the minimize button as a temporary solution.
    Regards,
    Marc Hens
    Edius 9.51 - Panasonic AG-AC90
    desktop: Windows 10 64 bits - Intel i9 9900K Coffee Lake - 32 GB RAM - nVIDIA Geoforce GTX1070 ti (8GB) - 2 TB M.2 SSD for video - 256GB M.2 SSD for software - 4 TB SATA for other data
    laptop: Windows 10 64 bits - Intel i7 6700 - 32 GB RAM - nVIDIA Geoforce GTX1060 - 256 GB m2 SSD + 500 GB Sata-SSD + 1 TB SATA
