encoding | batch | 6.51
  • encoding | batch | 6.51
    i have 3 files edited in edius,
    i wanna convert them in mp4,
    usually i do it in three times,
    can i load the 3 files and convert them while sleeping ?
    thanks
    j
    You can in 6.08, I assume they didn't remove it in 6.51 :)
    Instead of export to file choose batch export then open the next sequence and follow the same procedure .............
    Tony D.
      yes, you can it.....
      Exporting Multiple Ranges Together (Batch Export)
      You can export multiple ranges registered in the batch list together.
      1 Click [Export] on the Recorder.
      copy from the 6.5 english manual => (real) page 443
      or type page 465 in the Adobe Reader Page input field
      or type page 465 with foxit in the "go to page" field.
      this differnce is a "specialty" from only GV-manuals...
        page 473 in french manuel....
          ;) ... just for fun.....
          page 473 => as real page on bottom from the page or
          page 473 => as "specialty from only GV-manuals" on the "go to page" field from the reader??
