bit rate vs Sampling rate
  • bit rate vs Sampling rate
    OK-- this is a tough one, but I HAVE to satisfy a broadcast server that states the parimeters of the video and audio specs. The server MUST have the mpeg file designated as coded at a sampling rate of 44.1k-- I only see the reference of bit rate, not sampling rate-- anyone can tell me where I can satisfy the 44.1 requirements I need?- otherwise no audio will play when I put it to air.--- many thanks again, Ed
    Main System- HD Storm + Edius 7 Pro
    Win 7 (64),Asus P6T Deluxe v2 - Intel I7 - 12 G ram Gforce GTX 970 - 6 T internal-- 12 T Drobo Sata connection
    Secondary System- Edius 6- Win XP, Intel DH55HC i5 4T storage, 4G ram, Gforce GTX 260, , ADVC110
    if the server really requires 44.1k audio, then you can set that in advanced settings of the exporter
    http://www.videoproductions.com.au/e...r-advanced.png
    be sure to check audio properties after export to verify
      OOH-- NOW I remember!
      Thanks, now you mentioned it, I remember!-- Thanks so much!-- I can't believe what a great source of information on this forum and how helpful everyone is!- and you seem to always be there to help!--- Thanks again!-Ed
