If this is a VST plugin, I believe that you may need to imported manually after the installation. Open the effects windows in Edius and look for the import link or right click and select import (Can't remember well- I'm not with my editing computer at this moment) but something like that.
Hope it helps,
Use the VST plugin Bridge in the Settings to point to it.
