Hi everyone, when I'm editing using edius 6 although all my projects are stored on external drives Edius is using big chunks of my C: drive. It is a 120gb SSD vertex drive that has now turned red to tell me I only have 4gb left !! What's happening and how can I stop it none of my projects are the C: drive, thank you
Edius taking using drive space
EDIUS 6.0 - Intel i7 2600k 3.40GHz O/C to 4.50GHz CPU (8cores)
1x OCZ Vertex 3 120GB 2.5” SATA-3 for system, 2x Vertex Agility SSD for Editing, Multiple 1TB SATA III for video storage
NVidia GeForce GTX 550Ti Cuda 1024MB GDDR5 Video card
Windows 7 Ultimate, 64bit, 16GB RamTags: None
Search your c drive for an Edius Temp folder and see how big it isSystem Asus WS Z390 Pro MB, CPU i9 9900K, 32gb 3000mhz Ram, EVGA GTX1070TI, BM IP4K Win 10, BD Burner 1 Evo 840 and 4 Hotswap caddies
You may have erroneously built up a large 'Swap File' Start by checking it's actual size - My computer - open C:\ check the size of the 'pagefile' it would normally be about 2GB. If it is colossal you may need to seek the assistance of a computer expert.
Also check the sizes of files listed to ascertain the culprit, particularly Documents and settings - user (you) - local settings - temp. It's a good idea to delete all temp files after each session, see Antons excellent guides.
I have assumed WinXP.Last edited by Hawke; 09-27-2012, 11:42 AM.Hawke,
Edius 8.31WG - Asus Sabertooth X58 - 3.2GHz I7 960 - 12GB RAM - SSD C drive - Win7 Pro. 64bit - BM Intensity pro 4K. TMPGEnc Movie plug-in. FCB. Sony PMW-EX1 & Panasonic HDC-SD900. Atomos Samurai Blade
Thanks guys I'll check when I get back Home but I e already checked all the obvious folders in my C: drive what ever it is it's not obvious it's hidden :(EDIUS 6.0 - Intel i7 2600k 3.40GHz O/C to 4.50GHz CPU (8cores)
