Dslr Problem
  • Dslr Problem
    Hi all
    When i export my 5d footage to 1920x1080 50i for blu ray i seem to be getting interlaced lines on fast movements throughout the video can someone help me with the settings.
    Rob
    That means that your source footage and output settings differ.
    Bluray does support 50i. So if your source footage is 50i, then did you check your project settings to match?
    And if your're burning outside of edius, your export settings should match the source too.
    There's 3 things that all have to match (unless your converting): Source, project settings, output.
    Asus Crosshair IV Formula, Phenom 1090T CPU, 16BG RAM, Win7 64, 1TB SSHD Boot, 2x1TB Raid-0 Store, 2TB Print, 1TB print, 250mm fan. Edius 6.07, CS6, Spotify free.
