HDV Capture Audio ends short
  • HDV Capture Audio ends short
    Normally I work by capturing direct to Canopus HQ Fine direct from my HDV Camcorder a Sony FX7E.
    Recently I decided to try working in HDV Native to save some Hard Drive space.
    I have the capture setting to Split on Scene Change.
    Capturing HDV Native to MTS I notice that with each clip the audio ends short before 6-7 frames.
    Is this normal or a fault?
    I am worried in case this may induce any audio sync probs.
    I am guessing it is to do with the Long Gop 15 Frame Structure of the MPEG Transport File.
    Anyone?
    Anyone have any experience on this?
    EDIUS 6.07 currently using
    is this normal with HDV or a fault.
    I have switched back to capturing Canopus HQ Fine again for now just in case.
    Though would like to go Native HDV to save space
      can you do a test?
      disable any of the automatic scene divide options and start and stop manually and let me know if the audio is short
      I don't have a HDV deck to test
        I've never found this, capturing m2t from HV20 in Neo 3. Hm. Will try to test tomorrow.
          The same problem with Edius Neo 3.05
          I have the same problem with Edius Neo 3.05.
          Because I had problems with capturing in Canopus HQ, so I switched to MPEG TS.
          Edit system: EDIUS PRO 7.4 + Windows7 SP1 Home Premium 64 + Kingston 8GB RAM + I7-860 2.8GB + GA-P55-UD3R + 1X500MB Samsung Spinpoint F3 + 2X1TB Samsung Spinpoint F1 + Club3D9800GT 512MB.
            Problem solved
            Problem solved with HDVSplit (free).
              Interesting. I can't get hdv split to work on my windows 7 machine.
                I have heard/read more.
                Today I have version 0.77 Beta downloaded and installed and everything worked fine.
                  Addition to my last comment: I think it is important that a proper MPEG codec on your computer is present.
                    I just did an HDV MPEG 2 preset and captured without issue. File split is automatically selected and all worked fine. Check your cable.
                    Could you post a screen shot of your capture preset for MPEG HDV.
