Reopening project= read only
  • Reopening project= read only
    Sometimes when I open a project again I get the message that this project is a read only project and if I want to edit I have to do a "save as".
    Why does this happen?
    You should use Save as a new name, then you should be able to rename back again. Had a power cut this morning and had to do just that. I later deleted the new file from the project folder
      This means that you are opening either an Auto Save file or a Backup file. Normally this occurs after a crash or a shutdown that did not complete. These files can be identified by the numerical time date stamp that is added at the end of the project name.
        Thank you. That makes sense to me now.
