E-6.5 installation problems
  • E-6.5 installation problems
    Hi
    For some reason E-6.5 won't even start from E-5 upgrade.
    Sytem:
    New Dell Win-7 with i7 and 16 Gb mem.
    It installed fine and gave the old E-5 serial number, Etc.
    Click on the Edius will not start. Tried it with and without the HASP that came with older Edius versions.
    Anyone have this same issue?
    It's been three weeks and can not be started, no matter what I try.
    If your running anti-virus turn it off, or uninstall it to install 6.5. It depends on the anit-virus installed. Do a search of the forum and you will find a few threads about this.
      Hi
      Thanks for the reply :)
      It shows an error: "failed to create an empty file" .... sometimes and nothing else happens.
      I will re-install it and see if that works.
      The anti-virus was disconnected during install, but ya never know ...
        Are you installing from a disc or a file download? If it is a file download, I
        would download it agsin.
          Installation from a disk E-6.5 purchased from Videoguys.com
          I uninstalled everything and about to start again
          EDIT:
          I have re-installed as suggested.
          It appears can not be started if AVAST anti-virus is active.
          Hmmmm.
          Have to remember to trurn it off each time. Previous versions didn't have problem with AVAST.
          Thanks again for your excellent advice!
            Originally posted by kruzer View Post
            Hi
            You have an EDIUS 6.5 upgrade? ...and you are upgrading from version 5? That wont work.
            AMD Ryzen 9 5950X, AMD Radeon 6800XT, 64GB RAM, EDIUS X WG.
              OK, got it working.
              It's a CROSS-Grade 6.5 and it works well as long as there are no anti-virus program running. Otherwise it won't start.
              Thanks everyone for the assistance :)
