Animated menus?
  • Animated menus?
    Is this possible with E6.07 or would I have to use another program?
    What I have is a 30min concert, now under the menus I would like to have the title of the song with say a 3sec loop video clip.
    yes, just tick motion in the Edit Tab and type the time, 3 sec is a bit short, you can also choose fade in and out if you wish
    but first, I would update to 6.08
      Ok thank you!
      And one more quick question? What would be the best export preset that would give best quality?
        Originally posted by Los68 View Post
        Ok thank you!
        export preset for what? web? DVD? Blu-ray? windows media? quicktime? or just local avi storage?
          For DVD...
            For DVD...
            which software are you using foe Authoring? EDIUS? DVD-Lab PRO? TAW5?
            if EDIUS, simply go to movie tab and set to CBR 7700 max and dolby digital audio at 256
            if you have more than 70min, you will need to reduce the video bitrate until it fits, you can see the bar indicator at top
              Yes I was going to use Edius or possibly DVD Architect.
              What I was asking was which one.... Canopus HQ, MP4 etc...
                if not using EDIUS, for DVD, you need elementary streams mpeg, you need to use a bitrate calculator if timeline is say over 65min
                if less, use 7700
                Using Edius5 to export elementary stream mpeg files for DVD authoring in programs such as DVD-Lab Pro
