Not quite sure how to word this but when I copy a clip from another sequence using CTRL + C and paste it into another sequence I would like it so that the cursor jumps to the end of the clip. At the moment it seems to stay at the start of the clip. Is there some setting for this?
Cursor Position
Cursor Position
System:
Custom build PC: EDIUS 9 Pro; ASUS PRIME H310M-A Motherboard; Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz; 16GB Corsair DDR3 RAM; NVIDIA GeForce GTX 1060 6GB; 500 Watt PSU, 1 x 250GB SATA2 Drive for System, 1 x 1TB and 1 x 2TB SATA2 drives for video footage; Pioneer BDR-207DBK 12x Internal BD-RW Burner; Windows 10 64 Bit
UK & Ireland Cameraman and Video EditorTags: None
this can't be changed and I actually prefer it that way, because I can preview the cut point after pasting
press End to make cursor jump the the EndAnton Strauss
Originally posted by antonsvideo View Postthis can't be changed and I actually prefer it that way, because I can preview the cut point after pasting
press End to make cursor jump the the EndSystem:
Originally posted by Alpha Video View PostThanks. I was just hitting END but hoped there was a way of going to the end automatically. Nevermind, I can live with it.
but many users (including myself) complained because they wanted to preview the cut point before moving on
sorry about that chiefAnton Strauss
Yeah I prefer it stay where it is instead of jumping out of sight, I have to live with it jumping out of sight for a long time so it is now your turn to live with it.:-)I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
