DiscCreator crash (E6.5)
    Hm, now was able to export 100% of the timeline with disc creator after removing NOD32.
    So what gives? EDIUS HATES Anti-virus? 5.51 played well with everything.
    With NOD32 I had excluded Program Files (x86) and Windows....even tried disabling temporarily, it didn't work.
      just a quick question
      did you add the entire Grass Valley folder to the exclusion list of Nod32?
      this will prevent EDIUS.exe and licensemanager and DVD Creator.exe from ever being scanned
        also, one of my customers (no antivirus installed) was able to make Blu-ray and DVD with no issue, and one day it would not go past 83%
        I asked him if he installed any new software and he said he installed diskeeper, a disk defrag software
        I uninstalled it and Disk Burner worked again
        so I decided to reinstall Diskeeper and then Disk Burner failed again
        so now, Diskeeper is permanently uninstalled for the time being
        personally, I never defrag, my C drive is SSD, so no need, and the media drives only hold large files, so there will never be a need to defrag
          The 83% is a known problem, but in the past it has been associated with Microsoft Security Essentials. I suggest you try a reinstall of Edius with no Antivirus on the machine. After install, then try reinstalling NOD 32 and use the exclusions Anton suggested.
            here are the folders that should be added to the Nod32 exclusions
            C:\Program Files (x86)\Grass Valley
            C:\Users\Login Account Name\AppData\Roaming\Grass Valley
            C:\ProgramData\Grass Valley
            V:\The folder that holds all EDIUS projects on your video drive
            • #21
              Put back NOD32 for kicks (after getting the BD's burned without an AV) and added these to the exclusion list again.
              Lo' and behold, it crashes at 83%.
              Going to remove NOD32 now.
              Can I at least run EDIUS under a non-admin account? Standard??
              • #22
                sorry, I forgot, you need to add the work folder that you set in disk burner to the exclusion list as well
                • #23
                  I added all drive names (I Have network raids, named H, I, J, K, L, each 1TB)
                  • #24
                    can you set the work folder to a local drive and see if the export completes?
                    • #25
                      Same issue.
                      Just removed NOD32. Waste of money. :(
                      Trying to get it working so I can leave it to my editor so he can continue working.
                      • #26
                        as I said, all these antivirus issues will hopefully be gone after the next update
                        • #27
