Color correction in 10bit
  • Color correction in 10bit
    If you change the gray balance Cb and Cr value a little bit then if you change the value of Saturation to like 100.1, you see a big jump in saturation even though it is only .1, can someone duplicate this? wonder if this is a bug or not?
    Khoi is this in 6.51 or 6.07?
    I just checked in 6.51 and I don't get a shift as you are describing. If you can post a screen shot of the color correction interface after the big shift happens, I will try it again.
      Hi Jerry, 6.51, I forgot to add that you have to adjust the black balance contrast level to like a -5, then you will see a drastic change when you change saturation of Gray balance to .1
        Ok, I can get it to do it in 10bit, 8bit is fine. I will report this for you. The move is just to much for that little bit of increment.
          Great thanks.
