change bg and create slow motion with reverse
  • change bg and create slow motion with reverse
    hi guys.
    i have 4 questions
    1-how to create a part of a clip to show as slow motion or fast motion?
    2-how to change the background picture of a clip?
    3-how can i reverse a part of a clip(play from end to star)?
    4-when a clip is playing , i want that in a special time it zooms on a special area of a clip?
    Originally posted by omidreza View Post
    hi guys.
    i have 4 questions
    1. cut the clip where slomo needs to start and end, then apply the speed change (right click, time effect, speed, or use Alt+E keyboard shortcut) and type the desired speed such as 50%
    2. I don't understand because a clip does not have a background picture
    3. Alt+E and type a - in front of speed such as -100 or -50
    4. enter the layouter of the clip and create keyframes at start of zoom and at position where zoom needs to end
    example: http://www.videoproductions.com.au/e...outer-zoom.mp4
      thanks anton.
      1-for slow motion it creats slow motion very unreal and creats slow motion in audio too .please take a look at this clip below:(i want to create like this)
      http://pt88-mui.persiangig.com/video...%20675-cut.mkv
      2-for zooming if i want to create zoom in special area not whole clip what can i do?
      3- i have 2 other questions , if i want to remove something or someone from a clip is it possible?
      4- i wanted to change the red color of the T-shirt in below clip(2.avi) but when using chrominance i can not exxactlly change only the color of all T-shirt
      sometimes it change the color of hand and sometimes it does not change the color of whole T--Shirt.please help me or give me a best tutorial to change the colors.
      http://wdl.persiangig.com/pages/down...om/video/2.avi
        thanks anton.
        1. that is normal, if you don't want to slow sound, then place the clips sound below in an A track etc and your mkv clip crashes my browser
        2. I have no idea
        3. yes, but not with EDIUS
        4. play around with 3 way color correction
        http://www.videoproductions.com.au/e...color-3way.mp4
          2 duplicate the clip and put it on top.
          Zoom the whole picture so that the detailed area is as big as you want it.
          Apply the mask tool and mask the area with a circle or rectangle or a free-shape.
          Put the outside opacity to 0
          save and exit.
          Position to you liking over the non zoomed track Note if you want to position the zoomed area you have to put the mask before the layouter in the effects pallet
          This would mean that you would do the mask to first and the zoom.
            1-please try it with other browsers.i several times test it and it was correct
            3 way color correction worked good
            2-with which software can do that?
              To remove things (under certain conditions) MochaPro will do that. Have a look at their web site for examples.
              i7 3930K, Win 10 pro 64 Bit.
              RAM 32 GB.
              ASUS P9X79-Deluxe.
              PS Thermaltake 1kW.
              Graphics Gigabyte GTX1660 OC.
                For item 1.
                Try time remap. Should do what you want.
                Fred D
                  the time remap worked good
