Hi All
Could someone spare a moment to hand hold me through how to perform edits into a Target Sequence from existing Source Sequences and Sequence Clips so that the Target Sequence ends up with pointers to the contents (contained original clips) of the Source Sequence or Sequence Clip, rather than pointers to the Source Sequence or Sequence Clip itself?
For example:
Source Sequence "X" contains clips |1|2|3|4|5|
Target Sequence "Y" contains clips |a|b|c|
If I load source "X" into the source window, mark the region that contains |2| and |3|, and then insert edit that into target "Y" at an in point marked at |b| ... the result in "Y" would be:
|a|2|3|b|c| and not |a|-X-|b|c|
Thanks very much in advance
Andy
For example:
Andy
