Adjust Horizon (rotate clips) in Edius 4.24
  • Adjust Horizon (rotate clips) in Edius 4.24
    I am desperately trying to adjust the horizon on some of my video clips (the tripod was not exactly aligned).
    How can I do this with Edius 4.24?
    Us the 3D PIP, and zoom in a little.
    Ton
    Edius 7.31/ Vistitle / Vitascene Gigabyte GA-X48 DQ6 / MSI GTX 460 1Gb/Intel Q9450 2.66Ghz/Corsair TWIN2X 4GB DDR2 800Mhz/Coolermaster M620/1x SSD OCZ Vertex4 128Gb/1x 150Gb Raptor/ 1x WD 250Gb Sata II / 1x Seagate Barracuda ES.2 750Gb
      Resuming this topic just because I have the same problem: I need to rotate 90° a clip. The only problem is that I' can't fully understand w TonR suggested: I can't find that command...
        3DPiP = 3D Picture in Picture. it is a "Effect"
        Effectpalette ==> Keyer ==> 3D Picture in Picture ==> drag it on the clip ...(on the keyer-part from the clip)
          Thank you very much for explanation: I'm not very skilled with edius yet...
          The only problem is that (in edius 5) I have Effectpalette -> Keyer -> Blend, and only that. And in Blend there are no such effects...
          Now that I know what the effect I need is, though, I'll search for it...
            rotate?
            I'm trying desperately to do the same thing. When i drag the 3dpip nothing happens(only the picture becomes a little bit smaller).Can anyone help?Thank you in advance
              It sounds like you are in Hidden Folder view. Clcik on the little folder above the Effect Palette window. Central Europe has a screenshot of this in one of the other threads.
                Once you place it on the clip, double click the name in the Information Palette and the contril box wil open that will allow you to adjust it . If you do not know how to use it, check the Help file.
                  eventually it can help ??
                  I am sure you are in the "folder structure view" but with the false marked subgroup
                  "folder structure view" looks at where "all" included ... like other applikations or windoof-rules
                  there is not ...only the subgroup videofilters displays ...
                  go back to the "default view" ==> over the yellow marked button to the default view
                  ================================================== =======O
                  activate in the line from the yellow marked button,
                  the different button's (from left to right) to find all (hidden) effekts
                  I self missed in Neo 2.5 a lot of filters, and found for five minutes the way to see it
                  okay....dear GV.... you can saying, I am a old idiot...maybe to 50%... the other 50% is Imho on the User Interface-engeneering site
                  never see a folderstructure inside from a application, such inconsequential and such differently to all basic windows rules
                  friendly greetings from Centraleurope
                  friendly greetings from the "inhouse-librarian"
                  you wish a link or picture?? ==> call CentralEurope ....;-)
