Combine Filters, bug apply in project 10 bit of Edius Pro 6.51
  • Combine Filters, bug apply in project 10 bit of Edius Pro 6.51
    There is a problem with Combine Filters when applied in 10 bit project of Edius Pro 6.51, you can not do any stacking filters in it, unfortunately this screen always appears green spoils the clip... 8-bit project no problem, only the 10 bit there is that nasty bug. Here I leave the test.tpd to prove it in 10bit. I hope they can fix it...
    CSXD2 l For EDIUS Pro 6.5
    in my case, EDIUS crashes if I am not careful and add an 8bit filter in 10bit project, such as old movie film inside combine filters
    note: all 8bit filters have a blue dot
      Too bad, I share your discomfort Antons... I hope GV can review all these bugs present in 10-bit projects, that bothers the job to any.
        which filters did you load?
          Any filter that is activated and mixed in Combine Filters under 10-bit project, always throwing error... green screen, Edius crashes when just one clip makes a cut applied to the filter; Combine filters is practically unusable when working in 10-bit.
          Sure you might think, because stacking filters individually... but the downside of that is that the clip is made heavier to play, however with this process Combine Filters the clip applied maintaining the fluidity to play.
            what happens if you just trow all filters on info palette or clip and make your own combine by selecting all and save as user preset
            maybe the bug is just in the combine filter
              also, what is your project setting? I am asking because I don't get the green screen like you
                When grouping individual filters, and is created in a user preset, there is no problem in applying, but the trouble is that there is less perfomance in the clip applied... thing altogether when applied to Combine Filters, that there is order, practicality and better real time... is what I miss use this filter important.
                  is HD 1920x1080 29.97p... I've tried it in several projects setting 10-bit and it is the same, just try to modify Combine Filters or cut the clip you will see the error.
                    can I see a screenshot of all filters inside combine filter
                    I tried, YUV curve + 3 way CC = color balance and I can't get any green screen in 10bit 1920x1080 29.97p
                      Not only are mixed when these no problem, but if you activate or adds any of these in you Combine Filters with: Blend Filters, Antifilcker, Blur, Emboss, Smooth Blur, Tunnel Vision, Old Movie, Motion Blur between others, then there if ... please download the test.zip (containing the *. tpd) attached in the first post above. try that and see the error
                        I can confirm the problem with your preset
                        I am not a 10bit user because I have no customers who can watch 10bit, so I have not noticed that before
                          Unfortunate for any user you can work in 10-bit this problem is ratified... I hope GV can report to developers japan and solve this error makes uncomfortable work.
                            Try applying your filters in 8bit. Then go and change your project settings to 10bit. Does it crash then? I don't get the crash doing that.
                              Are you using the combine filters from 6.1? I get that weird look on jpeg image when using 10 bit project, but if I create fresh color correction from 6.5 10 bit project then I don't get that bug.
