HD Spark in edius 6.51
  • HD Spark in edius 6.51
    Few days ago , I installed edius 6.51 for trying. I have hdspark. I noticed that hdspark doesn't work as usual. From time to time, edius freezes. After restarting edius or windows (sometimes windows is freezing), hdspark doesn't respond. Solvation of that problem is: uninstalling hdspark driver, than restarting windows. After restart , windows install driver automatically. Sometimes hdspark start to work, but sometimes doesn't and I have to repeat all procedure twice. Is problem with driver for hdspark?
    custom PC No 1 ; mdb: Gigabyte Z68A-D3H-B3, cpu: i7 2600K, vga 1: 2x nvidia gainward GTX 670 (2GB), vga 2: intel ,ram: kingstone hyperx ddr3 16GB, sys HDD: SSD Transcend 128GB, monitors: 3x LG L225WT dvi, 1x plasma tv LG 50PK350 nle: HD SPARK, OS: windows 7 x64 ultimate
    custom PC No 2; mdb: asus P6T deluxe v2, cpu: i7 920, vga: nvidia gainward 275 (896mb), ram: kingstone hyperx ddr3 12GB, monitor: 2x LG L20WT dvi, OS: windows 7 x64 ultimate
    I think if you let windows install the driver you may not get the correct version.
    Can you check which driver is used?
    The correct driver for our hardware is installed at the installation of EDIUS
      Version of driver is 7.0.1.0. Date 6.7.2012.
      Btw, I intend to buy edius 6.5, but under the circumstances I was a little worried.
