3D Pip quality in 6.5
  • 3D Pip quality in 6.5
    I use the 3D filter a lot for animating stills, but have been dissappointed with the results when zooming in using Edius 6x (Layouter is good, but doesn't offer the feather edging.
    I have Imaginate, does a GREAT job, but does not have feather edging, and cannot animate the bordering and cropping directly.
    I plan on purchasing 6.5 Pro if there is an improvement-- can anyone tell me if there is an improvement in the 3D filter (the most important filter of all!).?
    Main System- HD Storm + Edius 7 Pro
    Win 7 (64),Asus P6T Deluxe v2 - Intel I7 - 12 G ram Gforce GTX 970 - 6 T internal-- 12 T Drobo Sata connection
    Secondary System- Edius 6- Win XP, Intel DH55HC i5 4T storage, 4G ram, Gforce GTX 260, , ADVC110
    3d pip is gone in 6.5x. However, if you open a previously created
    project from 6.x, it will still be seen as an effect. You will be
    able to do adjustments as well.
    Layouter is the replacement for 3d pip.
      No 3D Filter?
      Does the new Layouter have all the adjustment features of the old 3D Filter? and as easy to use?-- thanks so much!
        Pip
        Hi Ed,
        I played extensively with layouter when I got 6.5, I just ordered it...inevitable....
        It's pretty good I a/b'ed it with some pics I was using in a creative suite project...I think premiere might look a bit better, maybe. But Edius looks a lot better, than it did, I mostly gave up on it. So when 6.5 came, I had a difficult photo, shot from Hawaii with lots of rippling waves , moves smooth in premiere with some anti flicker, but in Edius it flickered enough to make the water to appear to be moving.....I applied the anti flicker filter ahead of layouter and poof looked great, worked better than any blur. Other photos worked well with out the anti flicker. I tried the various resampling algorithms and you could see the difference in some content. In any case turning on 3d seems to produce better results too. It has good key frame control, seems easy enough to use. You can save presets... Not sure if we can save as effects presets
        It has soft edge and drop shadow, I think lighting might be gone...
        The fact that you can use the real time gpufx with the keys is awesome...Edius' new power on non specific hardware will clearly be a selling point
        Here one for you GV, Are there any reasonably priced laptop I/O options in the pipeline?
        Jdroadie
        Philly, PA
        Edius 7.53 HDSpark, I7920, GTX470 Win7 64
          Storm Mobile :)
          Tony D.
            3d pip vs layouter
            Thanks so much for the indepth-- you have convinced me-- in the morning I am ordering my copy of 6.5-- Crazy Thanks!----Ed
              Even better...
              Layout supports file transparency and the new Shadow feature works amazingly well.
              I just finished animating a .psd logo with great results!
                Originally posted by SoundFreak_HD View Post
                That looks cool....capture anything is misleading with out an HDSDI port though...
                Jdroadie
                Philly, PA
                  Video Review
                  Rusty-- nice work- checked out your videos
                    It follows the statement of Edius 6; Edit anything, which is equally daring ........
                    Tony D.
