Edius 6.06 Wont Open
  • Edius 6.06 Wont Open
    Hi,
    Using Edius 6.06 on three machines and one of them edius will not open, its get half way through the progress bar on the small window and then Windows shows a message "edius has stopped working" and then prompts to close it.
    Any ideas guys??
    1. HD Storm+expansion bay,i7 1st: HD Storm+expansion bay,i7 920, Asus P6T,6Gb Corsair RAM,Ati HD4670 512MB,Lian Li PC-A7110B Tower Case,NEC 24" Monitor,Win 7, Edius Pro v6.06,Firecoder Blu card
    2nd: DV-Storm2,HD-Spark,Q6600 2.4Ghz,Asus P5Q Pro, 4Gb RAM, Ati HD4670 512MB,Antec Sonata Quiet case, NEC 20.5" Monitor,Win 7,Edius Pro v6.06
    3rd: i7 920,Asus P6T,6Gb Corsair RAM,Ati HD4870 1GB, Antec Solution series quiet case,NEC 20.5" Monitor, Win7,Edius Pro v6.06
    Gigabit Ethernet
    can you provide the error generated in event viewer/applications
      Do you have 3rd party plugins on the computer that won't open it, that you don't have on the first two computers?
        also, instead of clicking the EDIUS icon, double click a project file in Win Explorer and see if it opens then
          Hi, Thanks for your help guys but i tried all them things and still no help. I reinstalled edius and still same so i had to reinstall windows totally and then edius.
          Gigabit Ethernet
