EDIUS/Premiere Pro imports?
  • EDIUS/Premiere Pro imports?
    Here's one I haven't seen. Many of us use both NLE's now. Is it possible to import TIMELINES from one to the other. EDL's don't even match! Tried that! The only way I see is to go to an *.avi and import, but then all audio tracks (and video) are combined into one. Anyone have a better way?
    Thanks,
    Alan
    Alan J. Levi
    Director
    aaf and for transition compatibility use smpte
      Sorry, Steve, but I'm not following your shorthand in "aaf and for transition compatibility use smpte". Would you kindly take just a minute and expand that so I can understand just what steps to take in both directions - EDIUS to PPro to EDIUS?
      Much appreciated.
      Alan
      Alan J. Levi
      Director
        Export your project using AAF Avanced Authoring Format From EDIUS.
        choose the option to create new clip and choose the codec and output your wav too.
        If you have central storage you can use the option to use the original clips.'
        But then you have to make sure that the canopus playback codec is installed on the premiere system or you use a premiere friendly codec for your Edius clips.
        When the AAF is exported
        Bring the folder in which the aaf resides to the premiere station
        Use open/import AAf
        That is it.
        SR
          Thanks Steve. Will give it go over the weekend. Have a good one yourself.
          Alan
          Alan J. Levi
          Director
            AAF Premier import in Edius
            Use open/import AAf
            That is it.
            SR
            I try the reverse: Save Premiere project in AAF and Import in EDIUS...but did not function..
            Are there special presets to do in Premiere?
            THANKS
