Trying to print to a DVD, running DVD Creator, and my C drive is being used for temp files, and is filling up. Where can I reset the location of these files to my large media drives? Couldn't find it in Edius Application Settings, and there seems to be no settings for this in DVD Creator itself.
Changing DVD Creator Temp Files Location
Try this -
Use Control Panel -> System -> Advanced -> Environment Variables.
Create TEMP and TMP variables in your USERID and type in the path name of whatever drive letter + subdirectory you want to designate as your temporary work area.
Logout and login and test if it works ...TingSern
