Audio garbled when using DiscCapture
  • Audio garbled when using DiscCapture
    I am running Edius 4 and trying to import a DVD for editing.
    The DVD plays fine in Media Player but when I import the footage and play back in Edius all the Audio is garbled ?
    Arghgh what can be causing this.?
    Rog
    Audio can sometimes glitch and become corrupt from a CD that is ripped too fast, or if you have a cheap optical drive.
    With a DVD I’ve had a similar problem and used a different optical drive and it worked.
    I don’t think you can slow the read speed in Edius …..
    Good luck.
      Is the audio constantly garbled or just losing the odd frame?
      A few things to check:
      Does the disc contain multiple audio tracks?
      Do you know what format the audio is in? (eg. Dolby / MPEG / PCM?)
      A way to get around this - which is a sensible thing to do - is to encode the ripped M2P streams into HQ using Procoder. That way Edius isn't constantly having to reference a long GOP format. It might take half an hour, but we all have enough hard disk space these days.
      AMD Ryzen 9 3900X / 32GB / RTX2070 / 4TB SSD / Storm --- Edius user since version 1.5 and StormEdit before that!
        Garbled audio
        Thanks. I'll try your suggestions and get back to you.
        Dogeyrog
