Burn to Disc DVD Burn only problem
  • Burn to Disc DVD Burn only problem
    Using E6.5 New clean install of Win7 and deep reformatted disk caddy no AV
    When i try to burn disc using disc burner with write and create image ticked only the temp folder has any data on it,the image folder is empty no vob etc, the process stops after encoding,there is no update title 1 or navigation process. Using the same burner (LG) it burns Bluray ok its the same on a Pioneer DVD burner also
    The burn to disc works ok in E6.07.
    I have also reinstalled caddy to pre Win7 service pack1 just in case as this was the only change and its the same i can only asume 6.5 was always like this and it was the first time to burn
    updated with further info on 15/7/12
    Just on the chance bought a new burner allthough i couldnt see why it worked in 6.07 and not 6.5
    I was right it wont burn with the new sata burner so i guess E6.5 is getting me nowhere
      maybe it will work after the update that has been mentioned is coming
        Hope so because i dont have to burn to disc to create it. Just create a folder and the image files are not created
        If creating a disk the render dialogue disappears at 50% no error message
        I guess its a bug
          meanwhile, was there any antivirus or firewall or defender present when you installed?
            No firewall or defender
            I follow the instructions of that great master down under !
            Even reformatted HD to delete partition an d create that system reserved partition which was the only way i could get rid of
            info left by 6.5 demo
              did windows fail to reinstall after the 6.5 Demo was uninstalled?
                No windows worked but 6.5 wouldnt recognise the Licence hence the reformat with delete partition. At no time anything else stopped working
                i could uniinstall as i have an image but i will wait to see if update will cure it
                At present without plugins vistitle and no Burn to Disc its not much use apart from creating 3D mpg files to burn on 6.07 or Encore. My previous projects will include use of plugins
                6.5 has caused me a lot of work with re formating the (non delete partition) way restoring image then with the new re formatted drive updating windows and all other software etc.
                PS it works with Bluray
                  Update for 6.51
                  No change still wont produce a DVD from a 1440 or any other TL
                  Used a successfull 6.07 where it works for tests even prduced a new project
                  something prevents the disc being reused so it must be trying something
                  Previous wrong burn speeed choices in 3D trial and 6.5 have been corrected but i didnt see it mentioned in release notes
                    just a silly question
                    is windows explorer open while you try and make an image and burn?
                      I dont think its open but i will check i will also see if its running in task manager no windows were open or minimized
                      No nothing open
                        which drive is used as the EDIUS Disk burner work folder in detailed settings?
                        are you using a still menu, motion menu, no menu?
                          I am using for convenience the Desktop, have tried still menu (as supplied) and no menu
                          Update
                          The whole processs works if doing Bluray (checking the Compile Disc Image to folder option but not DVD
                          I am considering uninstalling Edius and start again (just Edius)
                          For info only
                          Yesterday i installed Nero Media Home 4 and although server was stopped and exit for anyone elses knowledge base it slows Edius startup to a crawl i have now uninstalled
                            the only Nero product I will ever install is Burning Rom and nothing else on any EDIUS PC
                              Update
                              For info only
                              can you try another drive, not the C drive or desktop
