Have just installed a NX Express card to replace my DVStorm2 and it seems to work fine with my Camera.
My only question is, Is it correct that it should be using "Generic HDV" capture option from the selection of capture options.
I know it's being picky but when I spent so much on the card I would have thought it would show as NX HDV capture?
Also why is it when I load the ADVC connection thing it complains that the DV cable between the cards is missing, or is it expecting to find a cable to an NX bay?
Is it possible I have left this connection in the wrong mode for Edius to only show Generic HDV?
My concern is if I'm using the Generic HDV capture does that mean the card isn't adding anything realtime to the actual editing process?
Cheers
Cheers
