Procoder problem when exporting from edius
  • Procoder problem when exporting from edius
    Hey guys this may sound weird but i installed edius 4 and everything is running fine, but now when i click on export inside of edius and click on procoder wizard, the wizard doesnt come up anymore even if i wait for 10 minutes... procoder works fine outside of edius, but not in edius, does anybody know what i can do to fix this problem??
    Plus i have captured 16:9 footage and worked out how to use it and edit it in edius, but with procoder not working in edius, i cant export the 16:9 footage from the time line, it only comes out 4:3, anyone know what i can do???
    I have no idea what to do now that procoder isnt working properly, even qtitler isnt working in edius either, i have installed edius again but procoder and qtitler are not working still...
    Need help.....
    Which version of Edius are you using 4.??
    I found that sometimes in edius procoder opens but is hidden by edius, I find it is in the toolbar at the bottom and by clicking on that I can see it.
    www.myvideoproblems.com
      yes i have edius 4, but no the procoder doesnt come up at all in edius, not even down the bottem as you said, just have no idea...
        sorry i have edius version 4.02, just got it,... had edius pro 3 before and that worked fine until the procoder and qtitler thing happened just boggles the mind...... any one got any ideas??
          run the ProCoder Express installer again and reboot, then it will work
