Vitascene Problem
  • Vitascene Problem
    Just noticed when applying a vitascene transition that the mid point of that transition seems to be transparent. In other words the full frame from video A to video B is not being seen. This seems to be a new problem for I have never noticed this before. Any thoughts on what is going on?
    Thanks,
    Ara
    Hello, you can send the following infos to "[email protected]" (proDAD support):
    - which Vitascene and EDIUS version do you use?
    - a short description of the problem, screenshots and protocol file
