Alpha Channel - How?...Please be patient
  • Alpha Channel - How?...Please be patient
    I confess to ignorance about alpha channels and there is no Edius tutorial on the subject yet. So, can someone give a simple explanation of how one might use it in Edius? My gut says mask a clip and save it with alpha then magically you add some clips together and the masked portion appears in the second clip. I'm guessing here and would appreciate a step by step description intended for a real neophyte. The 6.5 manual's treatment seems a little too thin for a beginner. The manual talks of a key but not how it's created. If it's by masking, what is the best way to accomplish that if the target isn't quite still? Mask each frame?? I hope not.
    As always, my respect and appreciation to you all.
    Gigabyte mobo with i7 K2600, 16G Ram, Storm Mobile, nVidia 570 but I'm just a hobbyist.
    After reading more threads,
    I see that chromakey and green screen takes the place of masking. That answers one question. But introduces another. Can if the original clip was not done with a green screen?
    I have much to learn and find this forum invaluable.
      play with the Mask Filter, you may like it
      http://vimeo.com/44625053 (shows how to use alpha etc)
        https://vimeo.com/44625053 Check this...thought it was great....makes me want Edius 6.5 more .......This guy did a great demo of the power of Edius
        Hey Anton, you beat me to it....lol.....
