project take long time to open
    yes, it is open now
      I fixed it, it opens in 2 seconds now
      1. you had one sequence with an out point marked before the in point
      (if your ruler is red, you know you have out point before in point)
      2. you had another sequence with a 17 hour blank gap from first footage to last footage
      (if you select zoom to fit, you see the whole timeline and you see the 17 hour gap)
        hi anton
        i do every tings same as you but it still take long time to open..can you upload that ezp project for me ?
          which version do you have? I opened it in 6.5 so it may not open in older versions but you can try
          by removing the 17 hour gap, the project file reduced to 1mb
          if you can tell me what version you have, I can re-download and open in the correct version
            its 6.02 thanks
            • #21
              Originally posted by roozbeh.roshan View Post
              its 6.02 thanks
              I don't have that any more, but I have 6.07 (it is a free update for 6.02 users with 100s of fixes)
              have you tried opening the file?
              • #22
                yes its open in short time but in edit monitor its like every file is offline but when i send file to player windows i can see them also edius doesn't show me any offline file in icon below timeline
                • #23
                  i use vitascene hieroglyph miracle and all new blue plug ins
                  • #24
                    do you install any codec for windows ?
                    • #25
                      so well. but my project is larger . its 3 hard each hard has 3tb movie . but i delete other sequence from bin and also time line except one of them but still i have problem and yes the autobackups is same.
                      this is project file thanks for your help
                      http://www.mediafire.com/?ty77s899xs28n63
                      3 hard drive 3TB each?
                      What kind of movie are you editing?
                      Edius Silver Status
                      Gigabyte UD5 X58, i7 950 , 2TB RAID 0,GTX 285 PCIe, 6GB RAM DDR3 1600MHz, OS drive SSD Corsair, 750W PS,Samsung 1920x1080 LCD, GVG HD Storm 3G, Edius 7.30, Windows 7 64bit Ultimate)
                      JVC DT-V20L3 20" HD-SDI broadcast monitor, multiformat
                      • #26
                        its a serial about war between Iran and Iraq its 46 episode.
                        • #27
                          I think it would be better not to edit all episodes in One project if that's the case.
                          If not ignore my comment.
                          • #28
                            i did it only 3 episodes in one project
                            • #29
                              it is very easy to relink offline files by simply telling EDIUS where the folder is
                              your version of EDIUS gets easy confused about offline files, especially since I opened the project in a different PC with a later version
                              ideally, you should fix the problem in your version, once you close the 17 hour Gap on the last sequence and clear the red ruler in another sequence by pressing X on keyboard, then save the project and close it, now it should load fast
                              how are your 3 hard disks connected? if via network or USB, it will start much slower, but never 45min, more like 45 sec
