compatibility Edius 6.5 and 6.05
  • compatibility Edius 6.5 and 6.05
    Hi all,
    I have a simple question. Is it possible to open a simple project (without crossfades, effects and all) that is made in edius 6.5 in edius 6.05
    The otherway should not be a problem but i need it to work from 6.5 to 6.05
    Have somebody tested this?
    Greetings,
    Simon
    A straight non 3d, non-alpha project without any effects or specific layouter
    effects will open in 6.07.
    I would not get in the habit of working that way.
    As 6.5 improves this backward compatibility may disappear.
      Be aware that things like Transitions are complete version upgrades and simple dissolves will not go backwards quietly! Replace the transitions and all is well.
      On the other hand, Quicktitler is updated and files open in the older version.
      Partial kudos to GV on this front!
        6.5 will not open in 6.07.
        Hi guys,
        I tried to open a 6.5 project in a 6.07 edius. No effects or something else on the timeline. The sound is ok, but i cant see the video.... AAH! All i get is a red screen. Is there something i am doing wrong???
          Yes. EDIUS 6.5 project will not work correctly in 6.07
          This has always been the case with EDIUS .
          Projects from newer versions will not work in older versions of EDIUS.
          If you do try it is at your own risk.
