Edius 6.5 Demo Installation Problem
  • Edius 6.5 Demo Installation Problem
    After starting, I get this message from License Manager:
    Cannot continue to use the trial version.
    Error code: 15.0.0
    Any ideas?
    join the club i have this too no cure yet i started a thread on friday night
      Did you guys install the 3D preview on that partion when it was available?
        I have not installed the preview version.
        I had Edius 6.07. First installation of 6.5 was good.
        Then install the new window and Edius 6.5. Second, only the error message received. (In these PC is there a HDStorm)
        The other on my computer everything is fine.
          The caddy with 3D preview has been re installed several times and replaced with the image of the caddy with 6.07
            Antivirus running during installation? Which one? MSE doesn't affect installation.
              Same problem on new Windows((((((
                No antivirus on PC
                  I installed 6.5 on my separate drive which was used for Edius 3D versions 1 - 8, these had been uninstalled - and I experienced this issue - re installing windows did not fix it either, only after a full format removing the boot sector did the install work.
                  Edius leaves masses of junk on you drive-
                  Paul
