EDL Exporting
  • EDL Exporting
    OK-- I have a project created in SP, now want to create a BluRay project-- tried to export the EDL using the Export EDL-- all I get is a dialog box-- "EDL Exporter--- video/audio file---- Connection processing" --- just hangs there-- any ideas?---- Thanks!
    Main System- HD Storm + Edius 7 Pro
    Win 7 (64),Asus P6T Deluxe v2 - Intel I7 - 12 G ram Gforce GTX 970 - 6 T internal-- 12 T Drobo Sata connection
    Secondary System- Edius 6- Win XP, Intel DH55HC i5 4T storage, 4G ram, Gforce GTX 260, , ADVC110
    The EDL export in 6.XX is corrupt, just hangs Edius sometimes.
    Dell T1650, 8GB ram, SSD, Win 7, Edius 6.08+HDSpark, Vistitle
      Aww- come on!
      THis is broke?--and hasn't been fixed?--- You gotta be kidding!-- Is there any other work arounds?-- I can't re-do the entire project!
        I have done quite a few wit no problems at all. Imported in to Avid and Premiere afterwards, just with the usual EDL sort of issues. I always export to CMX3600 - what settings are you using? How big is the timeline and is it full of effects? I normally remove all effects as well before making an EDL as effects cause problems, particularly with AVID.
