View Post
Edius 4.61
all looks fine
something must have gone wrong with the EDIUS installation
was antivirus disabled when you did it?
what was the first version you installed and then what update did you install next to get to 4.61?
can you uninstall and start again with the base full version and see if it starts, then apply the correct updates, but first I need to know your base versionAnton Strauss
Version 4 upgrade with version 3 serial, then version 4.61.
I don't think you can go from 4 to 4.61
what update did you install before 4.61Anton Strauss
I checked, yes you can go from 4 to 4.61
1. uninstall EDIUS and the Storm driver, reboot
2. delete all left behind folders in program files and documents and settings
3. empty hidden temp folder
4. install version4 and reboot
5. empty temp folder
6. install 4.61 update and reboot
see if it worksAnton Strauss
Originally posted by antonsvideo View PostI checked, yes you can go from 4 to 4.61
see if it works
[QUOTE=bobbyd;184016]I cleaned out the registry, did a clean install of Edius and all of the drivers including the hasp driver and the problem still exists. I even did a restore from a backup I made 2 days ago when Edius still worked. Also here is a screen grab of the license manager. Not sure where to go from here.Attached Files
Call tech support1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
what was the reason why you did a re-install in the first place? was something not working?
I have a feeling your dongle is dead, regardless of it lighting upAnton Strauss
Originally posted by antonsvideo View Postwhat was the reason why you did a re-install in the first place? was something not working?
was the operating system installed on a fresh drive or same drive
if same drive, did you do low level format as part of the installation to really clear everything or a quick format or repair install?Anton Strauss
Originally posted by antonsvideo View Postwas the operating system installed on a fresh drive or same drive
Here is what I got from Grass Valley this morning.
Bob,
The Edius 4.61 has reached End of Service status with Grass Valley and support options are limited or may no longer exist.
Please refer to www.grassvalley.com/products for currently available products.
If you require urgent support on this product, please contact Customer Service to determine what possible support options may still be available.
I will contact Grass Valley later today to see if they will replace the dongle. I think this may be the problem. Even though I have Edius 5 & 6 I still need 4.61 on ths machine for certain conversion projects and use of the DVStorm.
Finally Up & Running
Tech. support called and they took over my computer and tried different things to try and get Edius running again. Unfortunately nothing worked and I had to leave for an appointment. Thanks to Tech support for their efforts. They are great.
Out of frustration I re-formatted my hard drive again did a clean install of XP and then Edius. Everything is running fine again. I can only assume there had to be a corrupt file somewhere either in the operating system or Edius. All is working fine now. Thanks to Anton for all of your help.
good for you!! we still have 2 DVStorm working hard and hope to have its 2 running fine for a whileParanova Films
Cali - Colombia
http://www.paranovafilms.com/
