Just re-installed Edius 4.61 XP Pro. Edius started once and now I get an error that says "no hardare for Edius found". I have the DV Storm and all the drivers are installed and the latest haspp drivers are installed. Any help appreciated.
Edius 4.61
it means that your PC sound card is missing or the driver is missing or there are no speakers connectedAnton Strauss
"no hardare for Edius found" is only related to the onboard sound card
can you check if the sound is working if playing system sounds etc
it could also be an incorrect soundcard driver? any yellow warnings in device manager?
also, is the dongle light on? if off, this could also cause a hardware errorAnton Strauss
at what exact stage does the error appear after clicking the EDIUS icon on the desktopAnton Strauss
can you get a screen capture of the error and attach here
also, can you remove the dongle and see if it startsAnton Strauss
Edius 4.61
Here is the screen capture. Tried it without the dongle with the same results.
By the way thanks for all of your help.Attached Files
ahahhh, this is the Buy Now startup error
there has to be an issue with the dongle or its driver
where did you download the hasp drivers?Anton Strauss
Originally posted by bobbyd View PostFrom the safenet web site.
also, try alternative USB ports with the dongle
can you run the license manager tool from the installation disk and see if anything is on the dongle, get a screen capture, you can press print screen on keyboard and paste into image editing tool, save as png or jpg and attachAnton Strauss
Originally posted by antonsvideo View PostI wonder if the dongle is missing the license, this can happen if the license manager was used and the license transferred to PC
can I see a screenshot of device manager with sound video and game controllers expanded
also, with Universal Serial Bus controllers expandedAnton Strauss
