Is it possible to save clip markers along with .mxf .avi or other file?
Before editing I want to select only good parts of clips.
I dont want to store bad parts in archive.
I dont want to have thousends of small files but ONLY ONE per object and properly named.
(For instance - stamping_machine. mxf, rolling_mill.mxf....)
HOW TO DO IT ?
- I put all EX3 clips on timeline,
- next I make rough edit, delete unusable parts, clean it,
- divide to logical sections
- batch export them as .mxf file with the same bitrate and other setting as the source footage (mpeg2 35MB .... segmet encode ) not to loose anything.
- delete the souce footage.
A lot of work but the archive is small clean and usable after years.
Do you know any better way to do it?
If I could save each cut point as a clip marker in .mxf ( like chapters on DVD ) it will help the futher editing. Jumping from cut to cut.
HOW TO DO IT ?
