. . . in some players
Hi,
I am a beginner in post production (as well as in many film production related areas) and just trying to get an output of my short film
I want to get as high quality as possible output for 2-3 possible targets
a) DVD format for film festivals
b) TV broadcast
c) Online version for the internet
Would you please tell me what settings I should use/choose in Edius 6.01 in rendering the project situation?
My earlier related question (not being answerd yet)
my settings on a sample clip:
input: .mov 1280 x 720 MPEG-4 QuickTime
Codec ID : qt
Overall bit rate : 8 309 Kbps
Writing library : Apple QuickTime
NCDT : NCTG
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
project settings at edius 6.01:
Frame Size : 1280 x 720
Frame Rate : 25.00
Aspect Ratio : 1.0000
Field order : Progressive
Quantization Bit Rate : 8Bit
Audio Sampling Rate : 48000Hz
Quantization Bit Rate : 16 Bit
Channel : 4
Setup Render format : Canopus Lossless AVI
Over Scan Size : 3 %
Audio Reference Level : -20.0dB
After the render, I have tried to view the output
-with zoom player and there was no audio/visual synch
-with VLC there were no visual, just sound due to no support CLLC Audio and video
-BS Player view has no audio/visual synch
After I rendered it again with "Canoplus HQ AVI" standard settings,
I have watched it with no sync problem at all using BS Player
Have I done something wrong in the above situation please?
If so how would I correct the situation
all the best
Hi,
b) TV broadcast
Codec ID : qt
NCDT : NCTG
Format : AVC
Frame Rate : 25.00
Channel : 4
all the best
