Low Light
  • Low Light
    Shot some footage indoors in low light. What is the best way to brighten up the scene? Thanks.
    Not to be a smart a** but best way is to reshoot with better light.
    Short of that, it depends on the content, how bad the footage is, and what other problems it has beyond being "underexposed." For typical low light event (e.g., wedding) with some bright items in it such as lamps, I might first apply noise reduction (e.g., NeatVideo) and then apply color correction & brightness filters (e.g., YUV curves) to taste.
      Copy the clip and place directly above on the tl then add the screen filter
      You can then make adjustments
        Like John said, screen filter to the top clip and adjust its transparency track is the way to go for underexposed shots, you can also add about 20 motion blur to both clip if there are not much movement and you have some decent noise reduction.
          I agree. The screen filter has saved me a couple of times and then apply neat noise reduction. That is an amazing piece of software.
          EDIUS Workgroups 8 with NX Hardware plus HD expansion Card,
          EDITHD Workstation: Intel Core i7 [email protected], Nvidia GTX-950 Video Card, Windows 7 Premium, 64bit, 6GB Ram, Vistitle 2.6.0.6, Robuskey, ChromaKeyer Pro,
            Can also use the YUV filter and expand the mid levels and add some colour but make sure the waveform monitor is open to see what your doing and drag down the low level to around 0 to make sure the blacks don't look grey !!!
            Ron Evans
            Ron Evans
              How do you use the Neatvideo filter in Edius?
              How would the workflow look? I assume it doesn't work directly with Edius. What are the options?
              Thank you.
              Gigabyte mobo with i7 K2600, 16G Ram, Storm Mobile, nVidia 570 but I'm just a hobbyist.
                I used NeatVideo via VirtualDub. After capture I process the clips in Virtual dub, then edit as usual. NeatVideo is a commercial product, VirtualDub is available under the GNU General Public License ("free").
                If I have a lot of material but only plan to use some of it, I will do the rough edit, then process only the clips I intend to use. I substiture the processed clips in the bin for the unprocessed clips, then finish the edit doing color corrections, etc. as needed.
                Just be aware that NeatVideo noise reduction takes time - it can take a lot of time, so processing only the clips you actually use can be a significant time savings.
                Be nice if NeatVideo had a real Edius plug in, but none so far.
                  Could you be more specific about this filter please? I cannot find any reference to a screen filter in Edius itself and a search of the manual returns nothing also.
                  Edius 6.52; i2500K; Gigabyte Z68P-DS3; 8Gb RAM; 124Gb SSD for system, 5x1Tb HDD on board; 1Tb & 500Gb HDD off-board; 2Tb RAID1 out-board; BCF2000; Shuttle Pro2; Radeon 5 series dual display, HD Spark, HD monitor. Windows 7 Pro 64-bit, New Blue Fx Art Blends, Video Essentials 2, 3, 4, Titler Pro 1 and ColourFast, ProDad Defishr.
                    Screen is a keyer - not a filter => so look under keyers.
                    Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
                      HOW did you apply neat noise reduction on edius??
                      www.anima3dproductions.blogspot.com
                        I opened the .AVI file of concern in VirtualDub and applied the NeatVideo procerssion. This was outside the Edius environment. If only parts of a clip need noise reduction you may want to cut the clip (e.g., in VD) as a time saver.
                        As I understand it it is usually better to apply noise reduction prior to other filters that might overprocess due to noise content (e.g., sharpening).
                          Is there a substitute in Edius 7 for the "Screen filter"?
                            It is still there under the Blend filters. No need for a substitute.
                              What gives?
                              This post is almost 3 years old.
