Speed controller?
  • Speed controller?
    Hi everyone.
    I just saw thiw utility in grass valley site.It is written that it is and it is not officially supported. So what does that mean?Is it ok if i install it? And does this speed controller is the same as we say twixtor ?
    thank you
    I5 4690 CPU
    MOTHERBORAD GIGABYTE GA-Z97-HD3
    RAM 8GB [email protected]
    AMD RADEON HD 6800
    2X2TB WD CAVIAR BLACK (RAID 1)
    2X2TB WD CAVIAR GREEN (BACKUP)
    1 OCZ SSD 128GB
    Windows 7
    Edius 9&8 Workgroup
    Where did you find that :)
    Isn't speed controller something of the Canopus era, stand alone app, long long time ago .........
    Tony D.
      its the first time i see it so i wondering what is that. So is this something thats worth trying?
      I5 4690 CPU
      AMD RADEON HD 6800
      1 OCZ SSD 128GB
      Windows 7
      Edius 9&8 Workgroup
        Think this is the same utility that was used waaay back in the good old days of Canopus 'Let's edit.."Storm"....check the release date on it...2001.....so, good luck using.....hope it works with windows 7
          It states that is for use with Canopus DV files.
            Originally posted by George Glou View Post
            http://www.grassvalley.com/support/d...=&download=233
            Just right click in Edius on a clip and choose time effect / speed (ALT + E) and it does the same as that standalone app, except it's realtime in Edius, the app needs to render out a file and most likely only excepts SD Canopus codec :).
            Tony D.
              thank you everyone. I just thought that it is something new.
              thank you for the answers
              I5 4690 CPU
              AMD RADEON HD 6800
              1 OCZ SSD 128GB
              Windows 7
              Edius 9&8 Workgroup
