Noise reduction plugins
    I routinely leave the Edius environment to use Sound Forge NR. It is extremely effective, plus Sound Forge is a whole lot more than juswt NR. I suspect that if you cannot accomplish the processing of audio you need in Sound Forge, you just might not be able to do it.
    A few versions of Edius back, Sound Forge worked as a plug-in, but no more. Too bad for me. I'd really like to see Sound Forge plug-in support.
      I use Protools and Nuendo when i finish the audio in video projects, but i would like to get a god plugin bridge in edius so there i can use plugins from Waves directly in Edius, it saves time from exporting seperated audio tracks from Edius and importing them in to an other audio app.
      JoiCam´s
      And more
        SoundSoap Pro1
        I still use Soundsoap 2 VST plugin in Edius..
        Is Pro giving any good support for Edius ? Does it work as plugin ?
        BR,
        Deepcore
        Supermicro 2x Quad-core 5450 3GHz, intel 5000X, 12GB RAM, 12TB, Edius 6.5 HDSpark, Win8, 3x24" Samsungs, E-Mu 1616, Nvidia FX3700
        Sony Z1 & F-350, Canon 1D X, Panasonic HPX 3000 + Amphibico housing- Inspiration Vision Trimix.
