Are there any good noise reduction programs for Edius. I like the way Audition works. Any info would help.
Noise reduction plugins
If you have the money there is always noisefree, best i tested so far http://www.algorithmix.com/en/denoiser_pro.htmA computer with a lot of stuff in it :)
Originally posted by THoff View PostWhen I had to use SoundSoap in the past, I used it to output a new PCM WAV file with clean audio, and I substituted that for the original audio in my project. It doesn't slow down Edius at all.
You folks are saying if Sound Soap is applied to my project Edius will drop frames up the Wazoo? I think it might be wise for me to use Premiere for projects that need a lot of audio restoration work done. That is not to say Edius is bad but it may not be the best choice always.
Thanks for the info everyone
Originally posted by Ludde View PostIf you have the money there is always noisefree, best i tested so far http://www.algorithmix.com/en/denoiser_pro.htmwww.wishlistcentral.com - suggest new features
www.buglistcentral.com - report bugs
www.wishlistcentral.com/edius/ - Free edius user add-ons
Adobe Pro
Originally posted by alias View PostThat can be done but I also have Premiere Pro. To me rendering is rendering (converting/rendering). I think Premiere Pro might work better when audio is going to be an issue. Audition rocks!
Thanks everyone.
Thanks,
Ted
Thanks everyone.
Graham
I also use Tmpeg for ac3 encoding
in case of a long Edius project, I export timeline wav in 2 parts
then in tmpeg I load 2 dummy movies and add the unique wav files to each dummy
then I select ac3 output and choose to join all files to a single file, take 4 minutes to do 3 hoursAnton Strauss
