capturing movie doesn't work with new graphics card
  • capturing movie doesn't work with new graphics card
    I bought a new graphics card for my editing computer. It's the MSI NX7600GS. Since I've been using this card, I can't capture any movies on my hard disk anymore.
    Also if I want to look and play the movies, I was editing before, in the dual screen mode, the movie freezes. It shows only 1 image. it doesn't play.
    I hear the music play in the background but the movie is still!
    Is there anyone who knows this problem? and the solution to it?
    Dumbie
    Open Windows Media Player, then go to Tools -> Options -> Performance -> Advanced and try different settings for the Video Mixing Renderer and Overlay.
    Changing these settings seems to do something that the NVIDIA ForceWare drivers pick up, and it solved a problem I had over a year ago when I couldn't get Edius to display video -- it would only show a still image once the video stopped, or if focus shifted away from Edius.
      I remember getting this same advice from Torsten quite a while back when I had this problem and was beating my head against the wall when nothing else worked. It solved my problem and I would never have considered looking where he did.
        Which settings do I have to change?
        I tried changing some and then even rebooted my computer, but still it doesn't work.
        Also I have some "M2P" files on my desktop and they have now the WMP icon. Does this have anything to do with it?
        thanks!
          Are you certain any old graphics card drivers are gone. I would recommend uninstalling the drivers then running Drivercleaner to remove ALL traces of the drivers from Windows.
          I have had lots of problems in the past which turned out to be down to mismatched files due to older files / reg entries still being on the system
          Software:
          Edius 8.5 Workgroup
          NewBlue FX
          Hitfilm Ignite
          Vitascene 2
          Newblue TitleMotion Pro
          Smartsound 5.8
          Desktop:
          MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
          Laptop:
          MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
          Cameras:
          Panasonic HC-VX870 4K
          GoPro Hero4 Black
          Panasonic GX8 (Stills & Video)
          Garmin Virb 360
            I found it!! all I had to change was the Video overlay setting in the StormRT settings in the hardware settings menu.
            I changed it from none to "lock/unlock".
            All the rest of the program seems to be working fine with this adjustment, but if I find a problem with this, I'll let you know. but for the moment I can move on...
            thanks anyway guys!!
