Some plug-ins not showing in Edius effects panel
  • Some plug-ins not showing in Edius effects panel
    I recently installed NewBlue Essentials I-V and they all installed and activated properly. But Essentials II doesnt appear anywhere in the effects panels.
    I looked under plug-ins folder in edius and its there with all the others. I tried reinstalling it and still no luck.
    Any suggestions?
    Which version of EDIUS are you using? Do you have other third-party plugins installed besides the video essentials?
      No third party plug-ins except the ones that came with Edius 6.
      I installed Essentials that came with Edius first. Then a day later I installed Video Essentials I-V and only IV and V show up by them selves. I and III are actually in the regular Essentials folder. II is not showing up at all anywhere and Ive tried reinstalling 3 times.
        uninstall all NewBlue
        don't install the ones that came with EDIUS
        now install volumes I-V
