607 issue?? mpsegenc host???
  • 607 issue?? mpsegenc host???
    editing on 607 and computer froze, task manager showed mpsegenc host multiple times, then when i shut down edius, all those disappeared off task manager. any help appreciated
    Jim. With the problem you had in your last thread and Jerry's observations on your system's issues, plus other issues you have had. You really should get an engineer to have a look at it, or take it back from where you bought it and get them to look at it for you. You are getting close to a serious data loss if you have not been backing up. Just put the brakes on, pause and take a breath, then work out what's best for you and your system. Once you have it back in tip top shape you will be much happier, and only then really appreciate the time out to get it sorted.
      thanks, planning on that, any thoughts on that program that came up? first time
        I think it's dead Jim :)
        There is something 'afoot' within your system. Is the system out of warranty from the box store that built it?
        Based on the total sum of issues that you have had, you really need to either start from a fresh install and/or get an integrator who will work with you. This may be a problem because most integrators do not want to take on someone else's screwup.
        A fresh install, done properly, never hurt any one. You also need to sort out your drive problems. Personally, I would not trust the place that built it(unless it is still under warranty). Try and find an Edius integrator in Texas that is close to you.
        Here is one in Houston:
        http://www.bds-hou.com/
        They may be more for broadcast, but it would be worth the call.
        The only other one that I know that goes to Texas frequently is George. He supports a couple of systems in Dallas.
        Either way, it is going to cost money.
        Main System:: Azrock z690 Taichi, [email protected]hz, 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
          "it's life jim but not as we know it"
          Sorry Jim and Jerry, I couldn't help myself.
          Actually, Jim and Jerry, I suddenly feel like some ice cream.
          There are klingons off the starboard bow! It's worse than that, he's dead Jim! It's life Jim but not as we know it, not as we know it!
            what operation were you performing when it crashed
            what were the files used and what was the project setting
            mpsegenc is usually used when using segment encoding
              http://www.youtube.com/watch?v=FCARADb9asE
              That is pretty good. Especially, if your a trek fan.
